Convert file
bluekhbluekh Posts: 3
I have .PLT file type can print out for maker. and I want to use that PLT file for GERBER Cutter Machine to cut the fabric. How can I do?
  • VasylVasyl Posts: 877 ✭✭✭
    Hi, @bluekh.
    What kind of file you need: cut/iso or job (paragon)?
    Is it one time job or regular?
  • bluekhbluekh Posts: 3
    edited November 2020
    Hello, @Vasyl
    I need: cut file <Extension(.CUT) >for GERBER Cutter Machine. How can I convert from .PLT file to .CUT file?
    It's regular job for do that I only have file .PLT
    @bluekh ,
    Are there only cutting lines or some internals inside plt? Are present annotation? Is last one as text or transformed to lines?
    But if it regular jobs for you then you've ask partner for cut files exactly instead plt
    @Vasyl,
    Ok I'll try to ask partner for cut file. but I want to know that plt file can convert to cut file or not ? If can what should we do? thanks.
    @bluekh, yes - it's possible.
    Few years ago we made plt-CUT convertor for customer that bought gtxl but was making pieces/markers in Coreldraw.
    But!!! The plt file can contain the internal lines. There can be annotation present as polilines, etc. And all of this will be cutting.
    I can check my archive for convertor. And if it still present  i can to try convert your file
