Changing corners to have a smooth radius in PDS
BeverleyBeverley Posts: 82
What is the best way to make corners smooth and turn into a radius. See image below.
I've tried
Modify Point smooth
Modify Point smooth/line
Modify Line Curve
Modify Line smooth
All with not much success, or I'm not doing it correctly
Do I need to split lines or combine lines before I do any actions?
I don't really want to create a circle in each corner and use as a construction line to then add smooth points to my perimeter lines then move my points to match the circle, then delete the circle.
Any detailed step by step help would be appreciated
«1
