Alterations in cumulative mode not showing up
Hello Gerber Community!  Has anyone run into any issues when using Grade\view\alterations and NOT seeing the base size in Pattern Design?
This is happening on an AccuMark version 13.0 with hotfixes installed, when I use the function to view the alterations in the cumulative mode I am only seeing the alterations or the altered piece and not the base size.  I am in the cumulative mode so all alterations should appear in the same color.  I checked the colors and set them back to default.  I checked to make sure all the parts have the same size line.
