What version of Accumark allows you to export in mm ?
BeverleyBeverley Posts: 82
What version of Accumark allows you to export DXF in mm ?
I can export in cm on my version 12.0.0288
I can work in mm but not export in mm ?
  • Kathy ValadeKathy Valade Posts: 524 Gerber Staff 💛
    The unit is determined by the exporting system. If your storage area is set to MM it should be in mm and the importing system should be able to keep the same scale assuming it has the option to specify MM. Does your importing application have an option to specify the unit?
  • BeverleyBeverley Posts: 82
    I am exporting from Gerber.
    I can set my user environment to work in mm in my version but they don't EXPORT from Accumark in mm, the EXPORT in cm
    @Beverley
    There actually was a fix in V12.2 and it fully supports the Import of standard DXF in mm. I would recommend upgrading to V13.0 which is our latest version shipping today. Sorry for any confusion! If you would like to upgrade, please contact [email protected] or call 800-321-2448 and the Customer Solutions Center will assist you.
