Printer problem
MNM752AMNM752A Posts: 2
Hi we are a garment factory
I made a dress, but when making a bigger size we copy the smaller size and adjust the size and everything looks right, but when printing, the numbers and shape differ
  • MuhammadOwaisMuhammadOwais Posts: 293 ✭✭✭
    @MNM752A Do You take measures after amending the Pattern. And please would You elaborate further in detail like what software version, what kind or type of printer and how much is the difference. That might be because of wrong amendment or shrinkage or out-calibrated printer...
  • Kathy ValadeKathy Valade Posts: 549 Gerber Staff 💛
    Have you graded it from the base? You must follow the type of grading method in the rule table. Generate the plot and save it as a file. Then, take measurements of the plot file image. If it is only incorrect in the output, is this a Gerber plotter or a Windows Device Driver? t could be your printer or printer preferences.  Test that with a standard "10x10" rectangle.
