Error code on infinity plotter
auntbanaauntbana Posts: 9
We are getting the following messages on our infinity plotter.
error code 008: y motor and linear encoder are out of sync
error 032: linear axis is losing position
Can anyone help with these?
  • Jost LindemannJost Lindemann Posts: 46 Gerber Staff 💛
    auntbana, this reason for this message is:
    you have two encoders:
    1 linear (the metall-stripe on top of plotter)
    1 rotary encoder (buildin into the Y-motor)
    If these encoders do not count synchronized, you may receive this error.
    Most of operators will  replace the y-motor, but this is not required in most of the cases.
    But there are different items to check:
    - proper tensioning of the Y-belt
    - pulley on Y-motor-axis tight
    - mechanical binding on roundways
    - is linear encoder clean
    Most of the time, it turns out that there is something wrong with the positioning of the linear-encoder.
    Sometime it works if you take the stripe  off and put it back in again.
    There is a reader board underneath the head-board whih reads the encoder-pulses.
    Check if it is dirty or misabligned.
    Best regards
  • auntbanaauntbana Posts: 9
    Thank you, cleaned the strip and it is working again.
