Click and go
PascaleDahanPascaleDahan Posts: 13
What on earth is click and go? ...when creating sewing relationships in 3D. Please.
Thank you,
Pascale
  • Kristin RitterKristin Ritter Posts: 34 Gerber Staff 💛
    Hi Pascale, Click n go is a useful option set in Pattern Design preferences that reduces the number of clicks required to complete a task.
    For the function of creating relationships Click n Go is  especially helpful  to quickly select the sew lines with a single click to establish the relationship. If multiple lines need to be stitched you can use the ctrl key for multi line selection.
    Click n Go can be enabled in Pattern Design through the Edit tab/Customize/Preferences/General Tab
  • Jaye BrownJaye Brown Posts: 101 Gerber Staff 💛
    Hello Pascale:
    What version of AccuMark do you have? If higher than V11.0, then click and go is a default setting.   The click and go setting can be managed in PDS-Edit-Customize Workspace-Preferences-General tab.
    The purpose of click and go is to reduce the number of mouse clicks needed to execute an action in PDS...the idea being to improve user experience and increase speed within Pattern Design.
    I've included a screen shot of where you can find Click and Go as a reference.  I hope this helps.
    Jaye.
  • PascaleDahanPascaleDahan Posts: 13
    Thank you so much everyone for your prompt replies.
    Have a lovely day.
    Pascale
