Easy Marking - Copy to Clipboard 1:1
Aubrie_MeyerAubrie_Meyer Posts: 36
edited April 30 in AccuMark
Where do I find my marker image file, so I can paste in Photoshop? Or can I only paste in illustrator?
  • Kristin RitterKristin Ritter Posts: 34 Gerber Staff 💛
    Hi Aubrie, copied pieces from either Pattern Design or Easy Marking are available to paste into programs using the Ctrl V hotkey. In Photoshop, when you create a new artboard you can select the option Clipboard and the board dimensions will match the copied piece or marker.
    The Ctrl V hotkey also works to paste into Illustrator. I tend to paste into Illustrator as this program can view/access the vector paths of the pieces.
    Another option to create a file that you can open in either Photoshop or Illustrator, is to generate a pdf using Save As 1:1. This feature is available in both Pattern Design and Easy Marking and is located in the File menu for both applications.
