Error in NewtonJson.dll in YuniquePLM Credentails
bickinbickin Posts: 96 ✭✭✭
When I click Testconnection, the problem occurs "System.IO.FileNotFoundException: 'Newtonsoft.Json, Version=10.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' dosyasını veya bütünleştirilmiş kodunu ya da bağımlılıklarından birini yükleyemedi. Sistem belirtilen dosyayı bulamıyor."
My system is Turkish, so .net prepare Turkish detail explain but I translate that
"System.IO.FileNotFoundException: 'Newtonsoft.Json, Version=10.0.0.0 Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed'  Could not load file or assembly 'Newtonsoft.Json'
when I checking dll version, it is 12.0.2.23222 version not 10.0.0.0.
Do you know any solution about this issue?
  • VasylVasyl Posts: 719 ✭✭✭
    @bickin. Look for another dll location on C-drive. Maybe in window's folder. Backup v10 and copy instead v12
  • bickinbickin Posts: 96 ✭✭✭
    recently I fixed the problem.
    "Yunique.Core.Utilities.dll", "Yunique.API.DTO.dll","Yunique.API.POCO.dll" and "Yunique.SDK.dll" are  old version in "C:\Program Files\Common Files\Gerber Technology\PLM8"
    I change them in accumark v13/PLM8. The promlem is fixed.:)
