error accunest
kimkim Posts: 1
after using accunest, does it deform the original sample if any, what is the cause?
    @kim
    If You mean Deform the Pre-made Marker then Yes it can If You've selected the "Save if Better" Command or Turned on the Compact Option ON.
    But if You mean deform the Patterns then also Yes if You've provided any Shrink or Stretch Window while processing the orders.
    Otherwise I've seen no Deforms made by AccuNest since Years...
