Open & Closing Pleats
pnuevapnueva Posts: 1
Are we still able to open & close pleats, once other alterations are made to the pattern?  for instance, i added pleats to a front pant, then split the waist seam to create a waistband.  Once the line was changed, I could not go back and close the pleats.
  • Barry FuhrmanBarry Fuhrman Posts: 87 Gerber Staff 💛
    Hello @pnueva
    When pleat objects are created, you can open/close, edit, and delete them. Once you do something to modify the object outside of its own functionality -- such as splitting part of it away -- the pleat will no longer act as an object and you will be left with whatever notches and internal lines remain from the pleat. Recommendation: split off the waistband and make other adjustments before creating the pleat, if possible.
  • VasylVasyl Posts: 466 ✭✭✭
    That should be a cool enhance request: keep pleats, fulnes, maybe, darts on spliten parts.
    @pnueva @Vasyl
    PERU (Problem and Enhancement Report Utility) can be used to make enhancement requests as well as report bugs or errors.
