Community FAQs here! https://gerbercommunity.freshdesk.com/support/home
Printing markers with images.
When SaveAs 1:1 marker with images there miss sew line and notches.
Is it normal? How to sew the product without last ones?
What file type were you using?
BMP will show the sew lines and the notches (be sure to have them turned on in Settings), and PDF and SVG support the notch setting.
The BMP saves situation fo GMS.
Thanx
but for PDS...
Exactly, pdf is a single format for PDS SaveAs1:1. No notches, No sew line... but present other internals
I sended some reports already
The 1:1 works a little differently in PDS, and while it is only for PDF it does show everything exactly as in the PDS work area. Do you have notches and seams showing when you export from PDS? If so, I would expect to see the same in PDF.
I'm checking on v12.1.
Is it working on v12.2?
