Cutter Efficiency
Good Morning,
I’m looking into trying to improve our cutter efficiency and I noticed our dry haul time is greater than cut time.  Is this normal, or should cut time be greater?  I’m thinking cut time should be greater... If so, what is the normal percentage for cut time to dry haul time.  I’m thinking to improve dry haul I would need to check markers to se how the cut sequences are for the cutter?
Thanks,
Veronica
  • Lisa LowellLisa Lowell Posts: 568 Gerber Staff 💛
    Check the sequence of the parts, is the knife head jumping all over the place?  Have you tried sequencing the parts in AccuMark?
  • vhubbardvhubbard Posts: 18
    edited September 2019
    Hi Lisa,
    The reports I pulled was for all cuts that we cut for that week.  They have me looking into improving cutter efficiency so I'm trying to understand the reports and how the cut data goes along with the report.  I'm going to check on the sequencing for the parts in AccuMark and see how the pieces are placed.  If I'm thinking right, I need to check the start and stop point of one piece to the next, to make sure they are close to each other, to reduce the dry haul time?  So, am I thinking right that the dry haul time shouldn't be more than the cut time?  I'm trying to figure out what the normal percentage would be for cut time to dry haul time.
    Thanks,
    Veronica
    Good idea on the start and stop points.
  • wilson_daiwilson_dai Posts: 4 Gerber Staff 💛
    My experience, In the ideal mode, the next piece is close the cut piece. Max dry haul distance is less that 1/2 total perimeter of the cut file. But dry haul speed should faster than cut speed. so the idea dry haul time should< 1/2 cut time.
    To reduce dry haul time , You need to Optimize cutting sequence.
    Hi wilson_dai,
    Looking at our cutter reports that are generated from our cutter, it looks as though we need some improvement on dry haul time.  If I'm understanding correctly, dry haul needs to be at least half or less of cut time, correct?  in our reports all dry haul times are more than cut times.  Here is an example of one of our reports I've converted into a spreadsheet.  We are working at improving idle and interrupt times.  After seeing this post I'm thinking dry haul should be a lot less?
    Thanks for all your help
    Veronica
  • VasylVasyl Posts: 468 ✭✭✭
    edited November 2019
    @vhubbard, can you post here screenshot with P-cutter?
    We are off till Monday for the Holiday.  I will post screenshot with P-cutter table once I get back.  Just curious... is there a particular setting that I need to check on?
    There are maybe set sequence part cutting.
  • MuhammadOwaisMuhammadOwais Posts: 180 ✭✭✭
    Hi @vhubbard Same issue I've faced a couple of month ago. I've countered it by going deeper in this study case. We are using Gerber's Power Processor along with Manual Defining cut sequencing in Marker Making and Defining Cut Sequence in PDS. Our Gap Analysis shows a lot of improvement on our Cutter's Efficiencies (Paragon HX). Now I'm going for Cut Works to see if there I can improve more.
    Hi Vasyl,
    Sorry, been busy and just got a chance to post you a screenshot with P-cutter table.
    @vhubbard, oops. A Category sectiin is empty. Do you cutting data from direct acconark&oaragon, or use some preprocessing (cutworks, or else).
    One more question. Is cutter process piece-by-piece, or jumping from one corner to enither, then back to piece if prev section, ...?
