ben
 gerber plotter mp2200 please the printer head move alright but noting comes on the paper.
and the head some times moves with speed to the end and takes off
  • Dave RogozDave Rogoz Gerber Staff 💛
    If no ink is being put on the paper. Power off plotter. Remove the flat cable(s) from the board on the top of the print head going to the ink cartridge stall. Remove the cable from the stall as well. Reinstall the cable(s).
    If the print head is "running away". Turn off the plotter. Swap the CON 8 & CON 9 cables on the Master Board and the print head board,( board, on top of print head). Note: cables must be changed on both end or damage will occur.
