Sending DXF Files with RUL. File
tidivi23tidivi23 Posts: 113
Hello :-)
I noticed that when I convert a file to DXF using the DCU, it also creates a RUL. file. Is that an automatic function when saving a DXF and when I send a DXF file should I include that RUL. file with it, even if there is no grading on the pattern?
  • Kathy ValadeKathy Valade Posts: 422 Gerber Staff 💛
    Check your Export ASTM Options. Change it to Export as a Graded Nest choice. That will export your sizeline and any grading/nongrading points in one DXF file. There is no need to export with the rule table file unless your recipient will need to edit grading and send back to you. The graded nest option is preferred in your case.
