Anyone have issues with Markers not generating ?
DougWDougW Posts: 19
I had 8 models, opened each up in easy order and showed they all were successfully saved. 4 of them the markers generated within 1/2 hour, the other 4 still show as unmade and are not showing in the Queue.
    Hello Doug, Are you sending these markers through AccuNest? Your explanation is a little vague. Are you able to open these markers in Easy Marking? What are the AccuNest settings, were they the same for all 8 markers? What color are the markers in AccuNest? Are they all showing as blue?
  • DougWDougW Posts: 19
    edited October 2017
    Hello Lisa, let me clarify. I am opening the Model with Easy order, entering in required fields and hit process. It shows as Success. I locate the same file but the Marker "status " is remaining as UNMADE. They are also not showing up in the Queue. This holds true for 4 of them, and I have deleted the models and started over several times on each with no success.
    Lisa, I may have resolved my issue. I will follow up with you later
  • phartisphartis Posts: 1
    Hello, I am having the same issue and didn't know if you found a solution as to how to fix this? Thanks!
  • MuhammadOwaisMuhammadOwais Posts: 359 ✭✭✭
    @phartis Please Explain You issue further, And share Screen Shots if possible...
