error exporting dxf with data conversion utility
lynncatielynncatie Posts: 11
Good afternoon,
I have been trying to export a pattern as a single astm/dxf using the Data Conversion utility.
When I process the file, I am getting an error that the conversion failed, but no details.
Has anyone had this issue before and could offer help?
Using Akkumark V9 as i am working for a brand and using their system.
This seems to only occur with this pattern I have created newly and not with existing patterns I have exported before.
exporting the pattern using data conversion utility and using a marker.
I have assigned my usual grade table to all pieces.
Please let me know if you have any ideas.
Is there another way to export pieces as a single DXF other than using the Data Conversion Utilitity?
I have been getting the 'error creating piece' message before when opening pieces in work area and model editor, but the exporting has been fine in the past.
thank you so much for your time
    Can you attach the data?
  • lynncatielynncatie Posts: 11
    thank you so much for the quick reply!
    Unfortunately I am not allowed to attach any of the patterns.
    However I have found out that all pieces are able to be exported, except the back piece of the jacket: When I export this piece by itself I still get the above error message.
    Retrace the piece in pattern Design and see if that helps.
    I have just done a copy of the piece and re-saved it. it did work now!
    thank you!
    Has there been any new solutions for the 'cannot create piece' error? Unfortunately i am still receiving it when I open some of the patterns in PDS or Model editor?
    There is no image in the model editor for any of the pieces.  When that happens there is corruption with the pieces.  I cannot assist without the data.  You can email the data to [email protected] attention LisaLowell if you do not want to post the data here.  But I cannot really help without the data.
  • Sandro PalumboSandro Palumbo Posts: 11 Gerber Staff 💛
    Hi all,
    i haven't a bird eye, but, probabily there is a "space" character before the "F" in the piece name AW19--01-L- FRT-JKT...  : remove it and try again.
    The name of pieces, model, ecc must haven't special simbol (" " @ # ecc)
  • Kathy ValadeKathy Valade Posts: 478 Gerber Staff 💛
    Certain symbols are not supported, especially when foreign characters are converted from one operating system to another - ie: chinese to english. In this case, you may get dashes to replace the unsupported character, depending on AccuMark version. The detection on import to AccuMark has changed between V9 and V10 and higher. Again, please reach out to [email protected] so we can check this piece for you. We are able to detect the root cause with our own utilities.
    thank you so much for all the tips! i managed to save the piece and believe the errors were caused due to a grading-issue: there was a non-combined straight line at one side of the piece. I assume this was an issue for the SA and grading, as the piece was saved properly once i combined the lines.
    however i do repeatedly get "Cannot create piece whenever i load anything into the work aerator model editor.
    @Lisa Lowell would it be possible to sent you a few non-corrupt and corrupt pieces to the email you mentioned earlier? i would greatly appreciate if you d be able to have a look as i have been trying to find a solution for the "cannot create piece"-issue but am still searching.
    I have just sent an email. its a rather long one and I hope it will not be too long. Thank you for your help!
    What was the email address you sent the data to and from what email account name?
    Also, your piece had 1# rules. Modified rules will not export or import and will reassign a default size line. Check your Report Results for specific errors.
