Error regenerating markers AND errors in preview pane
We have Accumark 10/ AccuNest 10 ... after installing AccuNest, AccuMark gave us some errors:
- we can not REGENERATE a marker.
- we ca NOT see, in the previw pane of the Accumark Explorer - anything.
Can you share Screen Shot of the Error. It may be due to missing component required to regenerate the Marker...
Run Check One Storage Area - Verbose and then try again.
If we try to regenerate a marker, the program stops - recreates the marker with a different name ex. "-REGN6D1... "; the message in the activity log shows "processing order -REGN6D1...", and finished processing order "-REGN6D1...".
Before installing Accunest:
- Accumark did not stop; did not renamed the markers, processed all the changes we made in Pattern Design... it was all much easier than now.
About the run check the sorage areas - can't do that ( can only delete, rename, open etc. ) because it appears as an inactive "option".
Thank you all for all your advice and guidance.
Thanks a lot !!!
Please send in a report from the Problem and Enhancement Report installed to your desktop. Launch the application icon, fill out and email automatically based on your Properties setup. If you have to email the report attachments manually, please email to [email protected] attention Kathy and reference this post. We can submit on your behalf. It will provide us with all the details about your installation to assist.
Do you have translation files installed and if so, what language?
