Plotter Error with windows login
For some time I'm facing a problem about my Plotter. The plotter works fine but sometimes it gives the following error:
1. When i starts the User interface after the server:
2. When I try to add Direct Print.
3. When I try to do Composite Print
 The plotter is attached properly and connection is stable but won't allow me to send files.
The only solution I've found so far is to change the login of the Windows. The problem can be solved by using a fresh login on the system. But whenever a login go through the error, there is no way to fix the issues, Even not with the re-installation of the Server, UI and/or Driver...
