Adding a universal tag to every pattern piece in my system?
Good Morning Gerber Community!
I have been tasked with adding a tag to every pattern piece in the system. The tag is exactly the same for every pattern piece. Is there a way to add an annotation to all the pieces at once or when exporting a file via Standard DXF?
    You could add annotation in a "comment" to all pieces by defining it on your DEFAULT line in the annotation table. If you generate the standard DXF as a plot file, you can use the new annotation table and it will save that comment on each piece.
    See examples below for plotting from Piece Plot or PDS. PDS has the advantage of checking the Preferences box for generating all the pieces in the style in one DXF file.  Give it a try!
