Accumark Version 12 mm new feature
Finally we have mm option in Accumark Version 12 that I can use in PDS and reports.
Can you tell me is I can export DXF in mm or is this still in cm?
If so, where from and how?
    Hello Beverley,
    Good question, let me find out for you :)
    Hello Beverley,
    Converting out of AccuMark in mm is still under construction, so for now, if you convert out of AccuMark it will still be in cm.  Keep a look out for information on future releases.  You can check back on the status of the item which has a reference number of APDS-5914, use this number when inquiring on this feature. Thank you for using Gerber Community.
