Color matching in DIM BOM on size level
PM_DahlqvistPM_Dahlqvist Posts: 6 Channel Partner Member
Hi. Is there a way to handle color matching in BOM on size level?
  • Clayton ParkerClayton Parker Posts: 47 Gerber Staff 💛
    @PM_Dahlqvist
    I'm assuming you mean the ability to change the Material Color Pitching based on each size within the BOM?
    Yes, this is possible in both v7 and v8.
    Both versions require that you are working with a Dimensional BOM that is working with Size and Color Dimensions. From the BOM edit page click on the Multi Edit button (M), within the Color Tab you can define different color pitching options by size.
    The process is very similar within v8.
    Please note that the colorway page within the BOM will not be able to display this level of color selection.
  • PM_DahlqvistPM_Dahlqvist Posts: 6 Channel Partner Member
    Thanks – works fine 😊
    However …  might be a little tired of clicking. Currently, our client have a style in 10 different colours and with 30 different sizes – this will give them 300 clicks to fill out the colours for my size markers.
    It doesn’t seem possible to do through Material Group. how can this be solved in an effective way?.
  • Carlina BriscusoCarlina Briscuso Posts: 138 Gerber Staff 💛
    @PM_Dahlqvist
    Thanks for bringing this to our attention.  Let's discuss further.  Message me directly and we'll brainstorm for a solution.
    @Clayton Parker
    Thanks for the detailed post on using the DimBom!
    Try the following as a solution:
    By choosing only Size Dim, you can fill in for all colorways.  Then only have to click as many times as have sizes.
