PLT Issue?
Hi all I have been using the Gerber CAD system for many years now and have had no problems creating PLT file its the only way I can use my plotter. I have a new client who saying they can not see the files on there Automated Plotter they are also working on a Venitigraph CAD system which I am sending ASTM/DXF files for them to import
has any one had the same problems? and how did your sort it out.
I look forward to hearing of any solutions
Jacky Reynolds
Pattern Specialist
  • Sandro PalumboSandro Palumbo Gerber Staff 💛
    Hi Jacky,
    Often, the only reason because a software don't see HPGL files, is the file extension. When you generate the HPGL files, use same extension or not (HPGL, PLT, ECC) ? Try to ask your Customer what extension their software recognize (HPGL, PLT, ECC). Try to ask if the software have possibility to use *.* all file recognition
  • VasylVasyl ✭✭✭
    Hi @jacky, so what exactly type of file you send there: plt or astm/dxf?
    Can you put here sample? some one piece?
