Need Help to Upgrade
samsam Posts: 1
edited January 29 in AccuMark
I need to upgrade Accumark 10.1 to 10.4 i have zip file but there is no setup file will you guide me how to run setup ..
  • LisaLowellLisaLowell Posts: 45 mod
    You first need to extract the files. Once the files are extracted you can double click to run the Autorun file. Do not use the setup.exe file, use autorun. When the window opens select Accumark as the product. follow through with the prompts to install. Have you also requested a new license file?
