How to get files from Lectra to AccuMark?
Hi!
Can I somehow import pattern files from Lectra to AccuMark? I'm working on a project where I need to work on patterns that are made (by someone else) with Lectra but I use (and only have access to) AccuMark. What kind of file format should I ask for?
  • LisaLowellLisaLowell Gerber Staff 💛
    AccuMark has the ability to import in Lectra .mdl files. Is the data in .mdl format? Is the extension of the file .mdl?
    If so you can open Pattern Design select file\open. Change the file type to Lectra mdl, choose the file and import it. then save it to an Accumark storage area. To get the files back to a Lectra user, you will have to export out a dxf.
  • Thank you very much LisaLowell! I asked for them to send me the files in .mdl format, I'll hopefully get to work on them next week :)
